ebeeby
Member
I have checked the breather hose and it is NOT touching the black plastic air intake tube. The breather itself is the upgraded variety.
I get an occasional oil drip (a drop or two) from the lower joint before it enters the carb. You can see the fitment isn't quite right but it was the best I could get it early this year when I had to pull the jugs for pushrod tube seals.
1) Is there a trick to get the fit better where the black plastic tube enters the rubber boot that couples it to the carb? Maybe I should (carefully) use a heat gun to get things soft?
