I've recently acquired my first motorcycle -- a 1982 BMW R65. Today I decided to do some work on the brakes but have run into problems. I rode it twice the day after getting it back from the mechanic for a tune-up since the bike had been sitting for a long time. He assured me the bike was in good, safe riding condition.
When I got the bike the master cylinder reservoir was cracked and I didn't see any fluid in it from the outside, however I didn't open it up to confirm that until today. As a complete beginner I trusted the mechanic and rode without checking the brake fluid level, unaware of the safety issues.
So today, when I went to add brake fluid and bleed the brakes I noticed the front brake lever had no pressure. Yesterday I was adjusting the handlebar and controls position and unscrewed the union bolt (banjo bolt) to move it a bit. I am not certain but I think this is the point where the brake lever lost pressure, although it could have happened at another time when I didn't notice. Again, I don't know much about what I'm doing, forgive my ignorance, I'm trying to learn!
I followed the brake bleeding procedure in the Clymer manual and consulted http://www.bmwmotorcycletech.info/brakes.htm. There was still very little pressure with my thumb over the hole where I removed the brake hose from the master cylinder. I pumped the lever many times (50+), releasing my thumb pressure a bit to let air bubbles out. Air and brake fluid did come out, but only when the brake lever was pressed almost to the grips. I continued the process and tried bleeding at the bleed valve on the caliper. But, I couldn't get fluid to come out of the valve very far -- only 4 inches into the tube I'd put on the nipple.
What advice do you have? Where did I go wrong and what do I need to go read/learn about before attempting this again? Could it simply be the cracked brake reservoir? I'm skeptical of that because I was able to ride the bike for 50 or so miles with the brakes working, if a bit spongy, with what looked like no fluid in the reservoir.
I'll provide any details or pictures you need to help me with this. I appreciate your feedback!
