I have a shock on the front that came unscrewed from the lower half of the shock. It might have damaged the threads slightly I will try to clean the threads with a metric thread chaser. It will take a rather large tap and die to clean up the threads of that if it becomes needed. My question is how does the upper half come undone from the upper attachment? Is there a nut under the rubber bump stop on the piston shaft under the upper dust cover?
RickC
RickC
