oldslowguy
I think I'm at a point where I'll just be venting... Bought this pristine 05' with only 2k miles on it last August. Love it and have put an additional 6k miles on. Always had a problem with the height of the seat (I'm short), and never really gave the ESA a second thought, given that it appeard to be working (from all indications on the dash..), and the comfort settings do work. I bought new Hyperpro springs to lower it almost an inch, and having read up on as much as I could (re: the process to disassemble the Shock/ESA/Spring), started the install over this past weekend.
I had the settings at comfort and prelaod at 'one helmet' figuring the spring will be in its softest/lowest position, and easiest to remve the spring.. Then I saw a post showing what the shock/ESA should look like at the various preload settings, and now noticed that mine was still set at around 10 mil (indicating the 'double helmet' preload setting). Got me thinking.... I wanted to see, if in fact, the prelaod was even functioning properly, and after going through the 3 settings, noticed 'no change' in preload. That distance never changed from the 10 mil.., and I'm guessing is part of the reason the seat was always high for me. I don't think it was ever working... Arrrg. I think its been frozen in the 'double helmet' settings since I got it (even though the dash showed otherwise..). I guess this is ok, as I do ride two up with the wife (sometimes)... Anyway, wondering if I should even bother taking into BMW to see if any software updates will resolve this problem, or look to Hyperpro to purchase an upgrade shock to add the springs (already purchased)... I'm certainly not going to purchase a replacement BMW ESA shock. Wish I reviewed the issues with ESA prior to purchasing this bike.. Bummer
