Hello All,
With the help of a local MC service garage recently adjusted the valves on my R1200 (RT)
Small shop. Immaculate. Harley stuff mostly. Good guys.
Wanted too see if my skill for drag on the feeler gauges was good.
Whilst we were in there we adjusted the rocker arm end play first then the valves on each side.
After the procedure we pushed the bike outside, I suited up and rode her home. It was a small window of riding opportunity so I had to go go go.
Sounded a bit noisey when I started her, surprised me, but I needed to get it out of the shop and back home that evening. This was a few weeks back.
Last weekend I decided to adjust the throttle bodies b-4 replacing all the tuperware.
Got the job done , but all along I was bothered by the noisy r/s valves.
Kept hoping... I don't know what.
Today, b-4 replacing the tupperware I decided to inspect the r/s valves once more. Just to be on the safe side.
CRAPOLA... ZERO free play on the exhaust valves.
Stripped the left side to check those.
Everything else was perfect.
L/S roker arm play, L/s intakes, left side exhausts.
All perfect.
Went back to the right side.
Rocker arm play is perfect.
Intakes valves are perfect.
Exhaust valve had to be loosened 2ish turns. Couldn't even get and .05 mm feeler in there. CRAPOLA...
Well, I adjusted the exhaust valves, and buttoned everthything back up.
Started her up. Very noticeable sharp metallic tick from the , you guessed it, R/S exhaust valves.
Can't explain what happened. We were in a bit of a hurry due to the rocker are freeplay adjustment procedure being foreign to both the tech and myself. It took longer than anticipated.
He was working the R/S mostly. Thought I double checked just about everything though.
If anything I bet I'm guessing that we made a TDC error. I really don't know what happened and anyway I'm not looking to blame anyone.
I was in on this.
Something is now broken.
Question is, What is it, most likely that I have broken?
Bent valve? Valve seat? Spring? Other?
CRAPOLA
Dmilan
'05 R1200RT / now broken
All perfect.
I was in on this.
CRAPOLA
Dmilan
