Pushrod Centered in Tube
G
GTDOUG
This maybe a silly question but I noticed on my R100RT that the exhaust pushrods are not centered in the pushrod tube when the exhaust valve is fully closed. The pushrods are so close they maybe rubing on the pushrod tubes. This of course changes when the motor is rotated when the exhaust valves are opening. In reviewing Clymers manual nothing is metion about this.
GTDoug
Did you checvk last month's "Keep 'Em Flying" column in the BMWMOA News? This was addressed to a degree. The short answers are: "Yes it can happen" and "Do you own a dremel?".
Has the head been milled due to warping sometime in the past? That will also change the geometry.
What year RT? Later models had the updated rocker arms and needed the big fat washers under them. If someone retrofitted late model to an early model head, might cause some geometry issues.
Sorry about the lack of information...:doh It's a 1982 R100RT. The heads have been milled. I will check last months MOA issue.
Greg: Of course this is a later model, to my knowledge an earlier model head was not fitted to this motor. Everything I have read and looked up leads me to believe these are the orignal heads that have been milled, to my knowledge, only once. There is however 79K on the bike, so it is possible they have been milled more than once. I am still in contact with the previous owner and he does not think the heads were milled under his watch.
MAC: I hope your not serious about the dremel.:cry
Gentlemen, Thank you for your help.
GT Doug
83' R100RT
07' K1200GT
MAC: Thank you for your imput. The local BMW shop agrees that a little triming with a dremel on the pushrod is in order. I always get nervous when removing metal from a critical part.:bow
GTDoug
I would look at the pushrods and see if they are rubbing. They might look like they are rubbing and they are not. It is normal that they are not centered for a full rotation of the camshaft. Sometimes a head gasket is installed backwards and this may cause the pushrod to rub on the gasket as it is not lined up properly with the pushrod tubes. The pushrod rotates when in use. The shop recommends trimming the pushrod down in diameter? They know they are hollow, right?
If the heads have been milled, you need to add 4 washers to bring the arms back up to get the geometry right...or the pushrods will rub:doh
Check in the Book to see what the factory head deck heigth should be and find the difference to yours..that's the size of the 4 washers.
Dave is right that a backwards head gasket will cause rubbing...but the milling is more likely the root cause.
Greg and Dave,
Thanks for the timely responce. I am looking into the washer cure. I did not feel comfortable griding on a hollow tube. I pays to take your time on these kind of projects.
GTDoug
The airhead article is about CAREFULLY milling a tiny amount from the end/inside edge of the pushrod TUBE, NOT the pushrod itself! This is after examination that the pushrod was being worn down by contact with the sharp inside edge on the end of the pushrod tube.
