jimwjarmour
jimmy armour
Hi guys, stripped out the gearbox of my 2000 r1100rt and found the drive coupling was loose enough to make the knocking noise so have installed a shim washer to take up clearence, also noted my clutch push rod dosent have the slot for the felt seal/ noise damper, is this correct was there some bikes with a solid push rod, or should I have it machined and purchace a felt?
thanks in advance Jimmy
