I have owned about a dozen motorcycles but never one as strange as this 07 GS I just purchased. I was attracted to it after watching Long Way Down. So I traded a Yamaha FJR for this ugly and beautiful machine.
I have ridden a couple of hundred miles and have some questions. I would appreciate your input.
1. What are some of the common breakdowns I should be concerned about?
2. Do most of the R motors use oil or generally not?
3. When I release the throttle to shift, the bike seems to go over to the left a little, then right again on throttle. Is this normal?
4. Although it is minor, there seems to be a small surge while cruising in third between 3,000 and 4,000 rpm. (almost like a small variance in throttle position) Do R motors require injector cleaning?
5. Valves are noisey. It just had a 24K at the dealer. I think this noise is normal.
6. I wouldn't call this bike a rock on the pavement. It's kind of loose. I think this also is normal?
7. I have some mechanical skill. Can I adjust/check my own valves or must I pay the dealer hundreds of dollars to do it? I have been told that the R motor valves seldom need adjusting. Is it really necessary to check them every 6,000 miles? What are the signs of misadjusted valves?
8. What tire pressures do you run.
9 I'm 6'2". Are there any good windshield options that will not buffet my head? I tried a parabellem but couldn't find a comfortable spot.
Thanks for your comments.
Nate
Jacksonville Florida
Nate
