I recently purchased a 74 R90/6 showing 32k on odometer.
P.O. supplied many records of shop work he had done on bike (spent lots of bucks)
and last record of valve adjustment was at 28K but I was told it had just had complete fluid change and adjustment.
When I first attempted timing I found it at full advance at idle. So far I have changed points, (found points plate is bent and ordered new one) and managed to get it timed with the plate turned counterclockwise as far as possible and setting points gap at .015.
Timing helped but still wouldn't idle smooth and seemed underpowered.
Here is where I admit stupidity. After about 500 miles I finally checked valve clearance and found that at TDC there was no clearance on either side.
Torqued heads and set clearance and it is like a new motorcycle. Idles smooth
and runs like a spotted ape.
My concern is how much damage was done by running the bike with no valve clearance. My next step is to check compression and monitor for recession at 500mi and 1k intervals.
Any more suggestions are welcome!
