roger 04 rt
Some Results
Got out and made a few test runs last Saturday and did some more reading. Here is my 2 cents worth of thinking at the moment, and with apologies if any of it seems controversial ...
Since Bosch is relatively secretive about its Motronic product, it has been like pulling teeth to get an answer to the simple question: When do the Motronics MA 2.2 and 2.4 apply Closed Loop fueling adaptations to Open Loop fueling?
Although I'm still looking into this, what I've read (Bosch articles, handbooks and patents) and what I've measured (test runs) have led me to believe that it is much more likely than not that Motronics that use O2 sensors apply what they learn in Closed Loop operation to adjust Open Loop fueling.
As the Motronic learns how much more or how much less fuel it takes at each RPM/TPS position to reach Lambda=1 (during Closed Loop operation), it is making small corrections for fuel type (e.g. E10), airflow, fuel-flow, cylinder volume, battery voltage, etc. With my programmable-for-NarrowBand LC-1, I can reset the target air:fuel ratio and watch the Motronic adjust--I can see that happen for sure.
When I let the motorcyle adapt to a new AFR, and then force the motorcyle to Open Loop (through programming) the motorcyle runs much differently and the AFR displayed by the LC-1 wideband gauge confirms this by reading either richer or leaner than before. Then if I reset the Motronic by pulling its fuse and waiting a while, the AFRs are different still. (There are more things I want to try.)
Although this adaptive Fuel trimming has benefits that I listed above, here are some possible negatives that are hard to measure:
1. If your O2 sensor has aged and it is not efficient at registering lean mixtures, the Motronic will have to over-lean the mixture, learn that factor, and then lean out the Open Loop by applying the learned factor. This would have a negative effect on lean-surge.
It is hard to test an O2 sensor for accuracy. I'm not sure how any of us would easily do that. You can't tell how quickly it reacts to lean or rich and you can't tell if it is 14.7, 14.5 or 15.1:1.
2. Another likely outcome is that if you add an aftermarket product to adjust fueling, it seems likely that at first you would see an improvement and over time the improvement might be "adapted" out. However, when you disconnected that product, things would get worse for a while (until the Motronic readapted) so one might be convinced that the aftermarket product was indeed helping.
3. If you disconnect the O2 altogether, you might get a good result or a less than good result depending on how the stock fuel tables matched the specific tolerances of your motorcycle and the stoichiometric ratio of the actual fuel you are running (how much Ethanol).
The results of disconnecting the O2 might get better or worse if the Motronic was reset--meaning the Adaptation factors that had been previously stored while in Closed Loop were erased. I don't know.
One thing I know for sure is that my particular R1150RT runs much stronger (not that it ran bad before) at an accurate Lambda=0.97 (AFR 14.2:1) than it did with the stock O2 sensor. What I don't know yet is just what that stock O2 sensor of mine was doing. I will eventually go back and look at that.
