I bought a used top case and used Tommyboyz’s method above to remove the lock cylinder. It takes a little fiddling to get the release tab pushed in but it worked.
You use the same method to recode all the lock cylinders but removing the cylinder is different for each type of case or saddle bag. The “similar threads” are about different cases or say you need to buy a special tool or even take the case apart. None of that is necessary. All you need is a t20 torx and a small (I used a 1.5mm) Allen key.
Big thanks to him again.
