kbasa
Well-known member
In fact they are so dead simple, there really is no reason for them to fail other than poor design or poor quality control or lack of maintenance.
I added something to that.
I noticed that.
Maintenance? Is that item listed in BMW's maintenance schedule?
Brake fluid changes are, at least for the 1150s, aren't they?
12 years and 86,000 miles on the clutch CABLE of my R11GS.
I tried to top off my clutch hydralic fluid by using a very small funnel to pour some into the mechanism up near the lever.
After reading all of your posts I got a bit worried that I've been neglecting this important bit of routine maintenance.
I tried to top off my clutch hydralic fluid by using a very small funnel to pour some into the mechanism up near the lever. What happened is that the fluid simply leaked out of the other end, down at the tranny. It made quite a mess on my garage floor.
What am I doing wrong?
I've attached a diagram of the mechanism so someone can maybe point out to me where the fluid should go.
Thanks.
I dont understand the switch away from a cable either. In the cable system the release bearing isnt loaded or spinning when you are driving, only when you squeeze the clutch lever.
There is a pretty stiff spring inside the slave cylinder on the hydraulic systems that keeps the release bearing in tight contact with the push rod 100% of the time. So the release bearing has a 100% duty cycle.
This explains why the "screech" would go away when I would squeeze the clutch lever. There was enough "drag" from the fail(ing) release bearing to let some part stop spinning (and squeal from metal to metal contact). But when I would squeeze the lever, the force required to release the clutch that the release bearing would be forced to spin and the squeal would stop.
At least that's my theory. What is fact is the spring inside the clutch slave cylinder maintaining contact with the push rod & release bearing.
This is the equivalent of driving your cage with your foot resting on the clutch pedal. Just seems a little stupid to engineer it so the bearing spins 100% of the time.
I cand help but wonder why there are no comments on my observation that in the hydraulic clutch systems, the spring in the slave cylinder keeps the release bearing loaded 100% of the time. Like resting your foot on the clutch pedal in your cage.
This design seems stupid to me and would account for the short (seemingly) service life of the slave cylinder, atleast in my case where the bearing failed and overheated the fluid.
I sincerely hope I am wrong about the design.
Does it indeed put constant pressure on the throwout bearing?
well, your last comment certainly sounds like your assertion that the design is "fact" might not be quite so factual. IS that indeed the design of the slave assembly? Does it indeed put constant pressure on the throwout bearing?
