Norwood
That road looks good!
During the 2014 MOA Rally BaseCamp seminar, Dan Townsley mentioned these videos for beginners. I am listing these Youtube videos for your use. The only intend is to get you over the learning curve of BaseCamp. As you will note, these are non-professional videos produced by myself with screen recorder software. Also please note while the lessons date back to late 2013, BaseCamp has updates very often and I try to add Nuggets of information to keep current.
Using Window 8.1 - Zumo 660 -
I hope they are helpful. I have a discussion forum with some other very versed volunteers located at: http://forums.delphiforums.com/garminbasecamp/start
Each video can run from 2 to 15 minutes...
Lesson 1 - The Garmin BaseCamp Map and Menu
http://youtu.be/jDqVvHvd754
Lesson 2 - Data storage for Garmin BaseCamp
http://youtu.be/kpRaWRii7hE
Lesson 3 - Edit and OPTIONS
http://youtu.be/qwDSNPyVX-Q
Lesson 4 - Create My Collection, your database
http://youtu.be/stpwMUBQLNc
Lesson 5 - The Drawing Tools
http://youtu.be/ECNujneoot0
Lesson 6 - Backup Database, Google Earth
http://youtu.be/freaF_WciZk
Lesson 7 - Find, Search, Yelp, Icons and Data
http://youtu.be/ayGruPddSRE
Lesson 8 - Connecting your GPS and moving data
http://youtu.be/DZk5-wQbm84
Lesson 9 - EXTRAS on your GPS unit
http://youtu.be/fQmuT1tmVhM
Lesson 10 - Routing with NEW ROUTE tool only
http://youtu.be/1WkOq3_FurM
Lesson 11 - Routing with Waypoints your create
http://youtu.be/qB8N7nAGb_0
Lesson 12 - BaseCamp created route and then modify
http://youtu.be/pFTjsqucHSo
Check out Nugget # 4 at the bottom after this lesson Easier method with rubber band using the ALT key
Lesson 13 - Auto Routing using your data
http://youtu.be/mu4r-ee1XSk
Lesson 14 - Adding a stopover and your time element
http://youtu.be/MJbI5STi7uo
Lesson 15 - Common routing errors and how to avoid them
http://youtu.be/uS93soMx0Mg
Lesson 16 - Shared Data Files Conversion to GPX format
http://youtu.be/pnQSKZJd5So
Lesson 17 - Garmin POI Loader moving data to your GPS unit
http://youtu.be/uGvgv8mVPPw
Lesson 18 - Garmin Custom Waypoint Symbols
http://youtu.be/AuMFEzGNv3Q
Lesson Nugget 1 - Making your map larger and more controls.... short video. http://youtu.be/s1cD2v3xSKk
Lesson Nugget 2 - The best accessory for Garmin BaseCamp is the Mouse with center track wheel...as this video shows... Less than 2 mins.. http://youtu.be/R5ZBd04MoWI
Lesson Nugget 3 - How to extend a saved routed your created. I offer three methods...I hope to plant an idea that you may use. http://youtu.be/sO45PNp5Jns
Lesson Nugget 4 -The "ALT" key will make using the "Rubber Band Routing" method easy and simply and will use less keystrokes to edit data.
http://youtu.be/QiVT1QlvHEg
Update More great documentation to Learn Garmin BaseCamp for PCs and MACs
Kudos to Ed Conde for his Learn Garmin BaseCamp for PCs
http://www.newenglandriders.org/Learn_BaseCamp_PC.pdf
Kudos to Ed Conde and Steve Bruning for Learn BaseCamp for MACs
http://www.newenglandriders.org/Learn_BaseCamp_MAC.pdf
This documentation is an excellent presentation to help you Learn BaseCamp for both PC and Mac.
