RYD1WD
No, it's not. The chip is coded by VIN. The bike will only recognize a key coded specifically to its ignition system.Sounds like an easy way for a thief to get a bike at minimal cost if that's all it takes.
...With my R1200RT when I got the second fob the technician figured out to do it. He just passed the second fob over the antenna on the running RT and it started working fine....
Again, what is the benefit of this option?
I have a 2017 R1200RT. I bought the bike used, and got 1 keyless ride fob and 1 plastic emergency key. I decided to buy a spare fob, and I just got it a few days ago. The flip key fits my locks perfectly. However, I have been unsuccessful getting the radio transmitter to register with my bike. I tried several variants of instructions posted on the internet, including the instructions quoted above. No luck.
I bought a replacement FOB for my 2018 R1200RT and had to remove the windshield and the top cover over the dash to get right up to the antenna before my FOB would mate up.
I would think that once starting the bike with the original FOB present, and then moving the original FOB from the area while trying to train the new FOB would be helpful.
They get confused when multiple FOBs and other electronic equipment is present, so try that before disassembling your front end.
I moved the original FOB 100 feet away and the new one would not pair until pulled the windshield and the top dash panel off.
Does this mean that if I bought a fob I could go find a bike and get the new fob to pair with it? I am fuzzy on this issue.
I don't think so. When the fob is ordered it's for a specific bike via your ID and the vin number and pink slip that's why they require id and title. You cannot go up to any bike and pair it.
Thanks for these responses, they are helpful. Yes, when we buy a spare key fob from BMW, they come with the flip key already cut for our bike based on the VIN supplied at time of purchase. However, the radio transmitter has not been activated for our bike. So, we need to perform a process in which the new spare key fob becomes activated. That is what I have been unable to accomplish.
There are some videos on YouTube that seem show a trivial process of waving the new fob over the area in front of the dash panel, after the bike has been turned on with another key present, and instantly the new fob is registered. I wish that worked for me, but it doesn't. I have been tinkering with this for several days. I have been avoiding removal of the bodywork -- but it seems that is the next step. Actually, I think it might be easier to remove the left-side speaker rather than the topside dash cover.
And yes, I could take it to the dealer, but they want $100+ for the service, and that seems a bit much, considering I already paid close to $300 for the fob itself.
Cap
Here are are the instructions for programming a new fob.... required pulling the
two screws on top of the shelf to create a space to slide the body of the new fob into.
