justabill
Member
Ok. This was recently rebuilt. Everything is new or reconditioned. I've got a few issues to chase down, and this is one.
Occasionally, when I switch the engine to run but before pressing the start button, I will get a "chuff" sound. Two times, while testing other things, I got a loud bang. More of a single pop than a backfire. I am guessing at this, but I think the ignition is sending a spark to the plugs once it get's power. Actually, about one second after, which seems to align with the timing of the electronic ignition self-check. This spark seems to be igniting residual fumes in the carb or exhaust. Again, all a guess. I will take another look at the carbs to be sure they check out, but wanted to see if anybody else has run into this. The ignition is the EME electronic ignition, if that matters.
You can hear the chuff in this short video.
Bill
Bill
