Key Fob power status
robocop
I have a 2016 RS with the keyless fob feature. My question is simple: Is the key fob powered by a battery? If so, where is it buried in the fob. Question two: If the battery goes south in the fob then your up a creek unless you brought your emergency plastic key along. Correct?
Been with the bike 2 years, still learning GPS, ESA and Engine riding modes. Sometimes I pull out my 1965 Honda Super Hawk out from the garage and go for a short ride just so not to forget how it used to be........
You can start the bike with a weak or dead fob battery. Page 51 in your owners manual shows where to place the fob when you have a bad battery.
Page 52 in your manual shows how to change the battery in your fob.
I plan to change this battery every year and I carry a spare battery on the bike.
These are cheap CR2032 batteries you can find about anywhere.
There's a warning light on your dash that will signal that's the battery needs replacing. I replaced my key fob battery on the road, easy to do.
This video shows how to change the fob battery.
<iframe width="854" height="480" src="https://www.youtube.com/embed/TIbdzC5rqGA" frameborder="0" allowfullscreen></iframe>
The guy making the video must have exceptionally strong thumbs. Getting my battery cover off is quite the chore. :banghead
The first couple times I tried to remove the cover I gave up, figuring I was prying in the wrong spot.
After seeing the video I saw I was doing it right but needed more force.
I used my thumb like the guy in the video.
Nice, thank you for posting this video.
My 15RT, starting getting the low bat signal after about 18 months
Easy Peasy to change, carry a couple spares now, just in case
I found that keeping the fob in the same pocket as my smartphone kept the fob from working reliably. Even replacing the battery didn't help, I needed to separate them - different pockets was enough. I was really irritated for 6 months before I figured this out. Same with hotel keycards - keep them in a different pocket from your phone
