Those brakes will self-bleed with gravity flow alone if you have the patience to sit there and watch it and keep the reservoir full at the top.
My luck with a vacumn device has been dismal - they pull bubbles past the bleeder threads and I can never tell when I am really done.
The biggest problem most people have is letting air in from the top and then having to bleed and bleed and bleed to get the air back out.
If there is air in the system you may need to reposition the caliper so that the bleed screw is pointing stright up to get it all out.
