K100 Oil Drip
cuervo
Hello all,
I noticed an oil drip from my 88K100RS and went about investigating.
It is coming from the weep hole at the bottom of the water/oil pump.
Not a terrible drip, but one I would like to stop. I presume this means pulling the pump to replace the gasket to the engine? What all is involved and should I let the shop do it?
When I first noticed it, I thought it was the oil pan gasket and was ready to do it myself but now I'm not so sure.
tia
Cuervo said:
Hello all,
tia
Unlikely that it's the oil pan gasket (although mine weeps a tiny bit - and there is no gasket - it's a made-in-place seal - silicone sealant.
More likely the oil seal on the oil pump. You might check out the IBMWR tech-faqs for details on fixing it.
http://www.ibmwr.org
Note - the seals on the pump underwent a design change in the past year or so - the procedure to replace them is a bit more involved.
Given how old the bike is - if it was mine - I would go for a new pump assembly (it's a combined water/oil pump) - about $300 from your friendly local dealer.
Best,
More like around $350+tax now-a-days.
I bought one and thought about doing it myself but decided to have it done with a service 2 which will change the coolant anyway.
Sounds like a plan to me.. and I guess it is a few years since a friend bought a pump.. :)
Best,
I just replaced the seals on my K75. It cost about $40 for parts. There are some good tips on the IMBWR tech page. It's not a difficult job, but does take some time, and the installation of the water seal is a bit tricky, so read the IBMWR pages carefully.
