MinnesotaRik
Hi! I am a first time poster-- NOT a mechanic - also not afraid to get some grease under the fingernails
1995 GS 1100
57k miles
Second owner as of 2011
(With SWEET new KTC 80 knobbies! Golly, that looks cool!)
Last oil change last fall about 700 miles ago-- purple stuff, getting supplies together to get the filter and oil changed tomorrow
I got home from a highway ride and pulled into the garage after dark- I could SEE the dark orange glow of my catalytic converter. Are they supposed to get that hot?
I don't remember seeing that before.
It has been running rough since spring start/ like some flake in the injector -
Reminds me of when my old carbu Honda 500 would have some crud in the jet. Give it more gas and it suddenly clears and runs fine but then returns soon. I have already washed the air filter (yes, a K&N), replaced and gaped plugs-- the old ones had thin grey ash on the bent arm and black powder on the inside ring. One of the spark plug leads was not pressed home at first but now is solid- I have burned a tank with fuel injector cleaner- will burn one more before I plan to disassemble the injector area
Seems a little better ...
I had to readjust the clutch handle as I think I have lost another mm of clutch plate from wear--
I don't think the rough running is from the clutch as the roughness was intermittent- and improved after giving more power
So:
1. Cat too hot? If so what does that mean?
2. Ideas on next steps for the intermittent stumble
Rik
In Minnesota- OF COURSE going to the rally!
1995 GS 1100
57k miles
So:
Rik
