Independent BMW shops
Dann
Ok, I got tired of trying to locate a decent Gpx file so I made one.
I cleaned up the POI factory file which had a lot of errors and added shops from the "Internet BMW Riders - Independent shops and mechanics list"
The file contains 139 shops that I have verified the coordinates and if they are still open.
Some are other brands dealers that used to be BMW dealers but still offer the service.
I've indicated the shops that are on private properties and I've put a "?" on those that were on one of the lists but I couldn't confirm that they offered service for BMW bikes.
If anyone has any other shops they would like to add, please post the name and address and I will add them to the file.
Enjoy
  • BMW Independant shops.zip
I've added your message to the Resources & Links thread. How does your list stack up against the shops presented in this older thread?
https://forums.bmwmoa.org/showthread.php?35200-Independent-BMW-Motorcycle-Shop-GPS-Locations-2009
I've started comparing it with mine.
So far , the locations on mine are more accurate. (Some of them on this list are pretty off)
I know that some of them that are not on my list have been deleted because the shops are closed.
I will check the others to see if they are shops that I don't have.
I will have to check them and report back.
I should have kept a list of the obsolete shops that keep appearing on those lists so I would not have to check them again.
Daniel, no worries! I should probably annotate the resource link to indicate 2017...that way people can decide which source to consider.
I went through the list
I found 3 that were not in my list
The others were not included for the following reasons:
Cannot confirm location
USA AZ Tucson ZMW Z's Motorcycle Werks E. 44th St. #116 (520) 290-3374
USA AZ Mesa Bernie's Cycle Service 34 E. Southern Ave (480) 835-1420
USA IL Champaign Matthew Peek 1739 Westhaven (217) 403-1571
USA IN Linton T & B Cycle Sales & Svc 12th St SE (812) 847-7791
USA IN Delphi Perry Beemer Exchange 7413 E 975N (765) 564-6338
USA NJ Howell Mg Cycles 40 Vienna Rd (732) 886-6445 40 Vienna Rd
CAN ON Milford Bench Mark Works Canada 3020 CR10 (613)476-0494
USA NC Fairview Acme Motorcycle 1508 Charlotte Highway (828)628-0058
USA NJ Millburn Motorcycle Ron 175 Sagamore Road (973) 376-0466
USA WV Parkersburg Classic Cycle Service Nicolette Road (304) 428-3323
Closed
USA CA Chico Eurotech Motor Sports 1017 Willow Street (530) 345-7145
USA CA San Francisco Recommended Service 1064 Revere Ave (415) 822-2041
USA CA San Francisco Subterranean Cycles 886 Geary Street (415) 775-2999
USA IL Rock Island Tri-City Motorcycle Sales Inc 2219 3rd Avenue (309) 788-6552
USA PA Bainbridge Nissley Motor Co 160 Wickersham Rd (717) 426-3366
USA TN Nashville Collier Cycles 7401 Charlotte Pike (615) 353-1919
USA TX Pantego Boxers By Bruce 3620-4 Graves Blvd (817) 265-8065
Misc.
USA AZ Flagstaff Eurogeek Motosport 555 Blackbird Roost #5 (928) 773-8913 - Now Mountain Motor Sports
USA GA Alpharetta German Master Tech 5870 Atlanta Highway (678) 366-6145 - Car Shop
USA MI Niles Kurt's Motowerks 1990 South 11th Street Unit 12 (800) 472-4440 - Car dealer?
USA TN Cordova Memphis Motor Werks Inc. 9063 Macon Road (901) 757-1009 - Car Shop?
I've updated the file
  • BMW Independant shops.gpx
I just updated my info on IBMWR.
Virginia Motorrad
Anton Largiader
vamotorrad.com (434) 409-3767 1503 6th St. SE
Charlottesville, VA 22902
Sorry, i can't open the file but if you do not have Bombar's Beemers in Durham, NC you need to add them.
My apologies, but I was unable read the gpx file.
My mechinic would fit your description:
Ben's Motorcycle Works
80 Airport Blvd
Ste 105
Freedom, CA 95019
+1-831-786-8866
Sorry if you already have his information.
80 Airport Blvd
Ste 105
Freedom, CA 95019
+1-831-786-8866
Thanks for the info :thumb
I've added it to the file and will upload an updated version soon
As far as opening the file, I don't understand what's wrong. I downloaded it from the link above and had no issue importing it in Basecamp or uploading it on my Garmin Zumo with POI loader. :scratch
If you PM me I can always send it to you as an attachment.
It's already included.
As for opening the file, refer to my previous response...:scratch
Might mention the best program/utility to open it with. I took a look and don't have one- There is no application set to open the document “BMW Independant shops.gpx”.......running mac.
Just a thought.
Thanks for the effort.
Gary
From some of the remarks here, I don't think everyone knows what a .gpx file is. One definition:"GPX, or GPS Exchange Format, is an XML schema designed as a common GPS data format for software applications. It can be used to describe waypoints, tracks, and routes. The format is open and can be used without the need to pay license fees."
The key there is that the format is for designed to be read by software, not people. The GPX file can be "opened" with any text editor, but it is not easily read by humans.
Some of the basic formatting is explained in this Wikipedia article.
To be useful to non-programmer types, you need a program that translates the formatted data onto a map. Most route planning programs can do this, like Mapsource, Basecamp, Tyre, Locus, etc.
http://www.gpsvisualizer.com is a site will let you upload a .gpx file to see the locations using any web browser, either on a map, or as a picture or as a slightly more readable text file.
Some data in the file may not be visible in all programs.
To me the real value of Daniel's effort is that the file can be used on a GPS as a POI (Point-Of-Interest) file. So if I need a mechanic while on the road, I can find the nearest one as easily as I can look up a gas station or restaurant.
Just a thought.
Gary
Sorry to see that you're having trouble opening the file.
.gpx is a standard gps file format. Also known as GPS Xchange format.
It can be read by any GPS and is used to transfer data between them.
I think you can use something called "GPX viewer" on the Mac to view it. I've also read that it can be imported in google maps but I've never tried it.
POI loader is also available for Mac ( It's the Garmin software used to load gpx files to their GPSs. I don't know what the other brands use.)
Like Larry mentioned gpsvisualizer is pretty cool.
I use it to convert tracks from my rides on a google map type map and keep it for reference or send maps to my riding buddy to show him the route we will take on our next ride.
Hope this helps
Hope this helps
Actually I realize that I have no program to open it. I try to bring out "best" methods that will help the Members here on the forum. In these two posts, along with the file itself, you all provided a great tutorial :clap
Hopefully others will chime in with thanks.
Thanks for your efforts.
Gary
back to my Loran :brad
Here's my most updated list
These shops have been added to the previous list:
CAN BC Moto Concept Inc. 400 Brooksbank Ave #110, North Vancouver, BC V7J 2C2 604-929-2454
CAN ON Champion Cycle 325 Weston Rd #5c York, ON M6N 4Z9 416-658-7878
USA CA Ben's Motorcycle Works 80 Airport Blvd Ste 105 Freedom, CA 95019 (831) 786-8866
USA CA Marin Moto Works 44 Harbor Street San Rafael, CA 94901 415-454-7433
USA CA Metrik Moto 11928 Jefferson Blvd Los Angeles, CA 90232 (310) 390-0480
USA CA Moto Republic 5037 Eagle Rock Blvd Los Angeles, CA 90041 (323) 999-7828
USA CA Moto MD Powersports 7750 N. Sepulveda Blvd. Unit 6 Van Nuys, CA. 91405 (818) 779.7781
USA CA Motorcycle Performance Service 4150 W. Pico Blvd. Los Angeles, CA 90019 (323)-939-2370
USA CA Stoner's Beemer Stash 39628 Avenida Miguel Oeste Murrieta 92563 951-813-1704 (Airhead parts) - Private residence - By appointment only
USA IL Tukker ADV Motorsports120 E Main Street Colfax Illinois (312)-709-5709
USA MD Speed's Cycle 5820 Washington Blvd. Elkridge, Maryland 21075 (410) 379-0106
USA NC Motorrad Unlimited LLC 22 Piney Park Rd #9 Asheville, NC 28806 (828) 575-9996
USA NH Barrington Motor Works 216 Canaan Back Road Barrington, NH 03825 (603) 664-2673 - Restoration - By Appointment only
USA NY Cobb BMW and H-D Repair 1301 Brownell Avenue Lorain, (440) 244-6881
USA TX Austin Moto Works 6310 N. Lamar Blvd. Austin, Texas 78752 512-657-2659
I'm unable to confirm if the following ones are good, so if someone can confirm their location and if they do BMW work, I could add them to the file also.
USA MI Rick Pelton 9694 Chateau Interlochen, MI (231) 342-6509
USA MI Surrey Motorsports 1520 Bell Rd,Niles, MI 49120 (269) 684-0362 - Car shop?
CAN ON Milford Bench Mark Works Canada 3020 CR10 (613) 476-0494
USA NC Fairview Acme Motorcycle 1508 Charlotte Highway (828) 628-0058
USA NH Jim Pidgeon Manchester
USA OR Northern & Pacific Cycles Portland, Oregon - eMailed
USA SC Bill Gasque Conway, SC (843) 902-2434 - eMailed
USA VT Stanley Brattleboro, VT (802) 254-8554
  • BMW Independant shops_02_2017.gpx
please add
Sport Cycle Pacific
627 Salsipuedes Street
Santa Barbara, California 93103
Phone (805) 966-6508
thanks,
wyman
Latest Update
Added
USA CA Sport Cycle Pacific 627 Salsipuedes Street Santa Barbara, California 93103 (805) 966-6508
Removed
CAN ON Premier Cycle service 37 Bentley Ave Ottawa K2E (613) 226-4269
  • BMW Independent shops_03_2017.gpx
