I know I cursed it the other day by bragging that it started right up after I put in a new battery. Haven't ridden this particular bike in 2-3 years. I went on about a 10 mile ride, no problem.
I then put new fuel lines on the bike, and jb welded on one of the name tags that goes on the starter cover that fell off shortly after I got the bike way back when. Final curse?
I didn't use the bike for two weeks, but I have it on a battery tender. Of course, now it won't start. It turns over, semi-catches, but nothing. It's even worse with the choke on.
Now, I have to figure that somehow putting on new fuel lines may have done something, I may have knocked something loose, who knows, so today, here's what I did:
Took bottoms off of the carbs - both had gas, but not overflowing. Equal, respectable amounts.
Turned on the petcocks, and saw gas flowing into carbs. It likewise stops when I press up on the floats.
I checked the sparks upon starting (the lay the plug on the head and start the bike trick) - no problem there (it has a dyna ignition)
I then did a 1/2 A$$ carb clean - I pulled the main jets and idle jets, cleaned them, and blew air through them as well as the passages on the carb (still on the bike)
Put it all back together, and its a little better, but that may be wishful thinking. Still won't start.
Before I go completely mental here, what am I missing? I'm really stumped, becuase this is the only change since I last used the bike - the fuel lines, and there's gas getting to the carbs...
