I found a similar post as this but the bike was a a R100 euro spec police bike so the wiring was a bit different.
I checked the headlight relay in the headlight housing and all the connections seem fine. I traced the wires as per the Clymers wiring diagram and everything seems to be right. Fuses are good and all the connections to the circuit board are solid. The horn switch works and the yellow switch, when in the middle position turns on the rear light. When in the top and bottom position, the rear light turns off and the only light the works is the highbeam flasher which is activated in the down position on the rocker switch. I checked continuity on the h4 halogen bulb and all 3 terminals are ok. I contact cleaned and WD-40'd the switches. I'm totally stumped.
