Hi-vis color change on new Schuberth helmet
javadave
I bought a new Schuberth C3 Pro in "Echo Yellow" (Hi-viz) from the local BMW dealership 61 days ago. I've worn it for about 1800 miles of riding, but otherwise store it in my top case when not in use. I thought it looked kinda dingy, but when I popped off the air vent cover to clean, the color difference was dramatic as you can see. The paint exposed to the sun was significantly darker.
I cleaned the helmet using soap and water per Schuberth instructions, but the photo was taken after the cleaning.
The dealer tells me this is normal for all hi-viz equipment from all manufacturers. I accept that almost any color will fade after long-term sun exposure, but that usually means it gets lighter, not darker, and usually takes a lot more than two months of intermittent use.
Is this really normal with hi-viz colors, or is the dealer just feeding me a line?
I can't answer the question but do ponder how in the world some guy in a motorcycle shop became an expert in fabrics and plastics.
Any helmet manufacturer using hi-viz colors will tell you they will fade over time when exposed to UV rays. Thats why I keep my helmet in a bag when not in use; particularly when I'm riding and stop for lunch; it either comes in with me or gets covered.
Along those lines, hi-viz colors on fabric will do the same.
My Klim Induction jacket in hi-viz came with that advisement.
The attached was included with my C3 pro:
Joe
Yep, my hi viz Bmw jacket faded in a matter of months also. I don’t think in the OP’s comment that it’s getting darker, just fading...and the underlying color may be darker
