W
wxpotts
1980, r65
I just finished putting the bike together after doing a "spline lube" & replacing the tires & clutch cable..
The clutch will allow me to put bike into gear but when i let the clutch out nothing happens.
The bike does not go anywhere. I just sit there in gear revving the engine..
No oil or grease on flywheel or clutch plate, made sure everything turned prior to closing up drive shaft by putting into gear & turning tire. While bolting up u-joint everthing seemd to be turning & engaging properly.
Any one have any ideas as to why??
