I've searched this and ADVRider. My 89 R100GS has an aftermarket, rebuildable shaft with greaseable u-joints. It has a "click" or what I have heard described as "notchiness" at one point in its rotation. AFAIK, it's in the rear u-joint, near the final drive. It has a Works shock, it that's important.
I've read that heavily loaded and two up riders suffer fewer problems with the u-joints. My question is, would it be
necessary
desireable
or even possible
to change the driveline angle, short of adding ballast? About 80% on road riding, 20% on trails and fire roads. The closest to Paris Dakar I'll get is Paris, AR.
I'm fairly tall, but wouldn't mind lowering the bike a bit, in conjunction with a solution.
Am I obsessing? I suspect I should just put gas in it and ride. Thanks.
necessary
desireable
or even possible
