I didn't run the 750 for over a year, and never realized how bad the front-end dive was. In addition the brakes are grabbing, making for a dangerous combination.
Taking off the fork caps, it turns out there were no spacers, and no preload whatsoever. The springs are at least 20, 000 miles old. In draining the oil completely (doing a rebuild) it was quite gunky, and there were only 2 wiper rings on each shock absorber (damper rods), when there should have been three. What is the most likely cause of the front-end dive - the springs, the dampers, the used oil (also at least 20K), or the lack of preload?
