Front Brake Master Cylinder Leaking, 89 K75C
D
DEANCOX
Fluid is dripping out of the master cylinder assembly. In conversation with the parts desk at a SoCal BMW dealership, it was their opinion that it was like to be the master cylinder that was leaking and not the o-ring below the resevoir.
I have front dual discs, rear drum, no ABS.
Have any of you experienced this? Can the master cylinder be "tuned up?" I don't like the north of $200 price tag on a new master cylinder.
I have the manual that describes and shows the disassembly and reasssembly of the master cylinder, but it doesn't talk about whether you can stop a leak or any tune up type procedure.
Thanks in advance!
PS_if you order online from Beemerboneyard enter BMWMOA under "source code" in the "other information" box on the shipping and billing page for a 10% discount. :groovy
I bought a brand new master cylinder in January and I continue to get weeping of hydraulic fluid around the hollow bolt (banjo joint) crush washers. So purchasing another master cylinder is not always the solution to a problem.
What kind of washers of you using: copper or aluminium?
You may want to consider a new hollow bolt and/or new washers.
My master cylinder was leaking and it turned out the banjo nut on the brake line needed tightened. Check that first. I am amazed my 23 year old seals are still good!
Scott
Scott
It isn't the banjo bolt or crush washers, it is leaking out of the handle area. A new master cylinder rebuild kit arrives today. I will let you all know how it goes.
Got the rebuild kit from Beemer Boneyard, easy peasy replacement. Bled the brakes with my Mighty-Vac speed bleed and jumped on the bike and made a run to San Francisco yesterday from LA. Nice to have front brakes!
