Ok last August, I replace the large seal and bearings on the crown gear at about 182 000kms. The old seal was not leaking, just thought I would replace it while I was doing the bearings. The seal lasted for about 3600kms and then started leaking. It was a genuine seal. The old seal was installed flush, so I installed the new one flushed. You could see where it was wearing compared to the old one. So I installed a non-genuine seal a bit further in on the shiny surface. This seal has leaked from day 1. One of the mechanics at work said it will wear in. It is well over 3000k's, has slowed up ever so slightly. Should I put up with it waiting for it to take up, or should I replace it again. It is about a drop of oil when I stop and park the bike, but not every time.
Marc
Marc
