Final drive question
2slow
Got a problem on a 77 R100RS with the final drive blows oil out of the vent on top can the vent be taken out and cleaned the oil level seems right at the fill plug not sure whats going on any ideas thanks
They sometimes do that with abrupt temperature changes, especially when cold, or with changes of altitude. It is possible that moisture entrained into the gear oil may cause foaming, but sometimes air just gets chopped into the oil increasing its volume.
I've had it happen once on a bike and never again in 100K miles, on more than one different bike. I would be suspicious of moisture though, so changing the gear oil might be in order.
Did you experiment with gear oils - must use same weight of gear oil BMW specs
I tried 85w 140 once in the hopes it might stop some migration from
rear drive forward into driveshaft area.
The heavier 85w140 would sling up and come out the vent - switched
back to 80w90 and all ok again
thanks guys I'll try those things not sure what weight oil is in there as I just bought the bike this fall and yes it was cold today
Make sure your seal is good between the driveshaft and the final drive. I had gear oil venting and ot wound up being the nut securing the pinion gear on the fd came loose and the driveshaft oil made its way into the fd and relieved. The final drive oil level always looked fine but if I.drained the driveshaft oil it was always low. It's easy to take the final drive off and check
Gl5,
Its been for along time now,GL5 is used in most aps, less frothing, better overall than previous GL4s. Be sure you know whats in there? All my miles, never had this happen but yours clearly is, so! Some easy checks are in order; vent, drive shaft housing oil not migrating back, not much else. Good luck, Randy:usa
Final Drive leak
I've just discovered the same problem on my R90S. I picked up a seal and a tool from Cycleworks.net that will allow me to tighten the nut to spec.
DaveM
1975 R90S
2000 R1100RT
