Hi: I have 2009 RT and am getting together the tools to adjust my valve and was wonder where to get the proper feeler gauges for exhaust and intake valves, is it something from BMW or can it be purchased at Auto parts.Thanks Woody
One set will do!
Jim
I like the feeler gauge sets made by Hornig, available here: http://www.bmwmotorcycleaccessories.com/Metric-Feeler-Gauge-Set-HOR-21072110.htm
I like these because they are designed as metric from the outset, so they go up in .02mm increments instead of the weird and variable increments on most sets that are marked with standard and metric numbers. Very helpful.
Oh my. Special feeler guages. After I get my special BMW motorcycle feeler guages I will then get my special BMW motorcycle screwdriver.
Except for one little issue. This set has a .14mm and a .16mm blade, but does not have a .15mm blade which is the intake valve specification on R1100 and R1150 bikes we own. I can get closer with my .006" blade being .1524mm.
I still have the impact driver that I rode my bicycle to purchase so I could work on my Honda(s).BTW - that isn't THAT far fetched - if you ever wrenched on Japanese bikes from the 70's you'd find that the metric philips heads used (made out of solidified cheese) WERE a slightly different shape then a US philips bit. Combined with the soft metal, this was a recipe for learning how to remove stripped-head bolts.
Paul - time to contact the mothership.. your bike was shipped with a special BMW motorcycle screwdriver. It's sitting there all lonely in the minimalist current model toolkits (and.. and.. AND... A N D . . . the blade reverses in the handle giving you Philips and flat screwdrivers all in one tool - and there is a T25 Torx bit that also plugs into it. A virtual toolbox in a single tool!)
Well, just to prove that I belong to Wyman's official shade tree mechanic club, I have two hand impact drivers (not sure when/how that happened), one DeWalt battery one like JVB, and a big ass air impact driver that has absolutely no use on a motorcycle other than loosening up the bolt that holds the top of the front strut shaft.I recently discovered an impact driver for these screws, and it works way easier!
Jim
