F700GS Cold Temp Starting Problem
dellaster
My 2013 F700GS w/10000 mi seems to have a problem starting in the morning when it’s near freezing. Day before yesterday and today with frost on the bike, but not yesterday when the temperature was 41°F (it started normally in one try). I replace the battery the day before yesterday and obviously that didn’t do it.
What it does is fire up, the starter motor disengages, and then the motor will die within a second. Repeatedly. Soon as it warms up outside it will start as it should. There’s never a problem at any other time than when it’s near freezing air temperature.
I bought this last October and the day before yesterday was the first time I ever tried to start it in freezing temperatures. So for all I know it’s an ongoing problem from before I bought it, it just never showed itself.
Any ideas? Thanks!
Can you hear the fuel pump working with ignition on?
/Guenther
It makes the usual noises, no different from when it’s starting normally.
Edit: I’m not sure what sound that might be. I only hear the dash electronics when I turn the key on (just tested a minute ago—it’s 70F or so and it has no problem starting in one go). It’s not possible to test at freezing since it won’t get that cold where I am now.
Seems like it’s not pulling in fuel.
That makes two who think it might be fuel related. I’ve done some digging on this forum and elsewhere. I just reset the Throttle Position Sensor*, which was suggested in more than one similar situations, and I will add Techron in case it’s dirty injectors or other fuel system clogging. These are easy, inexpensive things I can do myself before thinking about other possibilities.
Unfortunately, I won’t know if either “fix” works unless I hit near-freezing temperatures again on my wandering-by-whim motocamping tour. I am actively avoiding such uncomfortable nights so it’s hopefully unlikely. This cold snap caught me and my weather apps off guard. But doing these two things won’t hurt and the cleaner especially might be helpful regardless.
Wild card cause: funny business with the fuel canister ‘cause the bike dropped on it’s right side a couple days before the issue occurred?
Anyway, I thank you and Guenther for responding. If anyone else has an idea I’m listening.
* Reset the Throttle Position Sensor: ignition on only, turn throttle handle from zero to full & hold five seconds. Repeat four more times ( five total) and turn off ignition for 30 seconds before starting.
Remove the seat and get your ears close over the fuel tank. You should hear the sound of a turning electrical motor. While doing that turn off/on the ignition which makes it easier to identify the sound if any.
If it is the fuel pump and we don't know yet then this fuel pump might eventually fail in warmer ambient temperature.
There's also a chance that the fuel pressure switch is not working correctly at lower temperatures. It is possible to remove the plug to the sensor and try again. The plug is behind the small triangular plastic cover on the right side of the bike.
/Guenther
/Guenther
Okay... there’s a tone from under the seat when the ignition is turned on. Upon starting I kinda think I can hear a whirling/whining sound with the seat off, my ear to the fuel pump area. That’ll be hard to detect if it’s not there—I can barely hear it as it is, when it’s staring normally. But I shall make the attempt should the non-start happen again.
I’ll also remember the pressure switch plug. Thanks!
