rmhayes12
Hello All,
An odd new intermittent behavior has started on my bike, which is otherwise running wonderfully. Sometimes, the right turn signal glows when I turn the key to the On position. It goes out once the engine has started.
Here's a detailed description of how I start my bike: 1. Mount bike and center it on tires. 2. Retract the side stand. 3. Ensure the transmission is in neutral. 4 Move the kill switch to the On position. 5. Engage the fast idle lever (when cold). 6. Turn Key to the On position. 7. Pull in the clutch lever. 8. Press the starter button.
Because it is intermittent, I am thinking it is either a bad electrical connection at one of the many wire harness plugs, or perhaps a ground wire that is loose on the frame somewhere. Has anyone else experienced this and found the problem? I am hoping to narrow the places to look first.
Thanks in advance for your input!
Rocky Hayes
Rocky Hayes
