Hello Forum Members....I've sought help from the forum several time....and received excellent information....
Well...I've got an issue with my 1974 R90/6
Started and warmed it up for 2 minutes or so, cut it off...ran fine...Went to get on and leave....switch on...nothing but headlight and tail light...no cluster, no starter, no brake lights, turn signals or horn. Battery connections are fine.
Fooled around with the shift lever...juggled oil pressure switch/Trans switch wires..cluster lights were intermittent. Finally they stayed on...started up and rode off...concerned.
While riding no horn, turn signals and when I'd tap either brake...the generator light pops on, bright red.
Got home, cut it off, 30 minutes later hopped on, would not start.
Hopefully this is something you can pass along your thoughts and or suggestions.
I appreciate your help and taking the time to read this.
Thank you very much!!...Mike
