T
tkpinsc
So when cruising, I've been riding by the tach and not so much the speedo. In light to moderate traffic I try to keep my RPMs at 3000-3500. Cruising I'll slip into 5th gear at 70 but still around 2800-3200. Does that sound right?
In light traffic (30-50mph), if I get into 5th it lugs waaaay too much and does it in 4th too. I'm probably just getting used to a boxer engine. This was my first weekend on the bike after bringing her back to life...so I haven't checked the mileage (Bing 40s, removed the EGR and its dual plugged) and not sure what to expect if I ride sanely.
Any thoughts?
No its not right. Your speed is reading to high for the indicated rpm.
It sounds as if your speedometer is ready 10mph or so fast at 70mph. This is very common for this vintage airhead. What you should do is use a chart like the one suggested to you to tape a speed to expect on your tach in a certain gear at a certain rpm for reference. Usually the tachs and odometers are accurate.
