I've been an MOA member for a few years, but this is my first post here -- apologies in advance if I've picked the wrong place to post this.
I'm planning to put a car tire on my 2011 R1200RT. The goals here include longer time between tire changes, better handling in rain, and better handling on occasional dirt/gravel detours.
Based on what I've heard from others, together with my 17" wheel size, I'm currently considering the 205/50/17 versions of the BF Goodrich Comp 2 All Season (MSRP $165) and Bridgestone DriveGuard Plus All Season Run Flat (MSRP $265).
I've already ordered a spacer and slightly longer replacement bolts to handle the wider tire (vs 180/55/17 stock).
What opinions can folks share between these two tires? Is the extra $100 for the run flat feature worth going for? Does the higher mileage rating advertised for the Bridgestone (65k) vs the BFG (45k) manifest in longer life / higher miles on the road when used in this way?
Are there other tires you've used that you'd recommend above these two?
