K
keelerb
I've got a new clutch cable I figure I should lube before installing (84 R100T). Anybody got a recommendation as to the lube to use?
Thanks - BrianK
Thanks - BrianK
Disagree, cable and wire rope fail from internal friction of the strands, has nothing to do with movement in the casing.
In a word - don't. Back in the day one did need to lube the cables, but now the cables come with a teflon liner. Adding a chemical lube will cause problems with the liner and you'll have to replace the cable again.
