Best way to drink water when ridding?
134833
Hey everyone,
Just wondering how must people drink water and ride. Do you use a simple water bottle in the cup holder, a hydration system (CamelBak), or a drinking tube? I would think that the CamelBak would make you hot and the water bottle would be impossible with a Full Face helmet. Any advice or tips would be appreciated. Thanks
Ride Safe.
Mark
I use a camelback with a 90 degree angle before the bite valve. Works fine with a full face helmet.
The key is hydration, not cooling. If you want cold water, fill the camelback with ice and wrap it in a towel. Refill each gas stop.
I started using a Camelback while shooting Black Powder Rifle Silhouette in Texas several years ago. The model I have holds about 70oz of water and is easy to use while riding. Using crushed ice and water you can comfortably cruise for 150>165 miles before stopping for gas and refilling with ice and water. Ride Safe
Any of those bladder bags work fine. Some FirstGear jackets have pockets and grommets to accommodate them. I've got a tank bag that takes one.
If you put it in your tankbag, place it in the bottom compartment, seperate from any electronics. DAMHIKIJK :banghead
I use an insulated camel back that is not a back pack type. I added a tube extension so it can be strapped to the my drybag on the back of the seat or pillion plate and the tube is within reach while riding.
Unbottle Camelback: http://www.rei.com/product/750000
Tube extender:
http://www.rei.com/product/610513
two downsides:
1. the tube is long so on really hot days (when you need it the most) the first sips are warm even if there is Ice in the bag.
2. Getting on and off the bike is a bit more complicated by having the tube pulled around from the back.
Hey everyone,
Ride Safe.
Mark
Mark, as several have already suggested, the CamelBak is a great option.
I've been using mine for the past year and even on the hottest of hot days have never minded or felt uncomfortable having the small pack on my back (I use a BMW Venting Machine suit, btw). The great thing about the CamelBak system is that the bladder has a large opening and accepts several cups of ice, which I've typically gotten at gas stations, convenience stores and diners. I've had to replace the bite valve once, and at $4.95 it was a worthwhile repair (and that was only due to damage it had suffered by accidentally closing one of my system lids on it).
Best of luck to you and welcome.
Gross But Always Cold Water
I have one addition to the camel water pack. First I try to fill it with either hotel ice or ice from the MacD's or other such locations. It will stay cold for hours, no matter how hot it may be. My bag is insulated but still the first sip on a hot day is hot water from the hot tube.
Now to gross you out. I only recommend this if you are not sharing your camel pak. Once I finish my sips of water (done every 10 minutes), I blow into the tubing forcing all of the tube water back into the camel pak. This leaves the tube empty. When I take my next few sips of water, 10 minutes later, all the water the that I receive is icy cold. Repeat with emptying the tube again. Works for me.
Isn't the CamelBak just a little overkill?
I've ridden hundreds of miles with one on a bicycle in the hot summer where if you didn't you might die of dehydration, but more probably "bonk" after an hour and be forced to stop and recover. But that was sweating bullets every inch of the way. I have "bonked", and know not to let myself get that dry.
I have read the medical, scientific info on dehydration effects and what it does to mind and body, but what makes you think you're going to suffer from dehydration if you only drink two or three pints of fluid every hour or two (gas stop)?
I work in the hot sun nearly every day in the garden or farm, and often doing serious hard work, as in mowing with a scythe, but more usually using a hoe, digging, chopping, cutting, hauling, carrying, lifting. I sweat profusely - which is probably why I can do the work. I can easily drink a gallon or more of water in a day, but I don't have to do it more often than every half-hour or so.
When I'm on the bike I fill up when the bike fills up. I'm confident in my judgment and sense of physical well-being, and I don't think a CamelBak is a necessity while using a machine that propels itself without my labor - at least not for me.
If you truly need the immediacy of a CamelBak - go for it, but I would suspect there's an issue of physical fitness that should receive your attention.
(I mean no disrespect or harm to anyone here.)
Iron Man
As a middle aged male, I found that if I drank enough water to keep me hydrated, that amount of water usually "translated" into the need for a a stop aboout every 90-120 miles, which shazam! is about when I want to stop for the GS anyway!
I tried a camelback, and found it, like many modern convenences a hassle, plus I hate to have plastic pacifier in my mounth..yucck! I always carry plenty of water, so if the need arises, I stop on the road, have a couple of swallows; not like I'm trying to win an Iron Butinski or anything:)
But each to their own in this wonderful world, and more power and I mean NO disrespect for others who like a pull on the sack while riding down the road!
+1:drink :drink
I had to stop jogging due to a bad lower back, but I did jog up to the age of 56 (last year). I ran in the afternoon and would run up to 1 hour in 100+ July and August temps with out drinking. I stay all day with no air conditioning. I am a product of the old school football practices with no water. We did not even have water on the sidelines during a game.
I do drink a lot of water during the day, but not constantly, every couple of hours. After an hour or two I will pull over and get a cold bottle of water out of a small ice chest I carry in the hard bag.
More people have died running marathons from drinking too much water than too little. Dilutes the body's sodium levels. There is a name for it, but it escapes me.
Ralph Sims
Best Camelbak
Is the Stoaway, insulated and insulated tube with cover for mouthpiece. In tank bag with my shield wiping cloth on it, no problem. Bag will stay cold all day if you fill it up with ice in the morning. I got the 100 OZ size.
Hey everyone,
Ride Safe.
Mark
Hi Mark -
When I ride, I like my scotch "neat." To add water just dilutes the taste. :drink
J.K. :wow
JK, you are the very definition of a rascal (Webster # 2) - but your momma already told you that, yes?
Must I state that I'm kidding, or will the context suffice? - I don't want to get thrown out of here...
Me too!
I'm with ya, homey!
I'll usually freeze a couple of bottles of water, then put them in a soft cooler in one of my sidebags with a couple of unfrozen bottles. I drink when I stop. I stop when I need to:
- Fill the tank
- Drain the bladder
- Fill the tummy
- Stretch the legs
- All of the above!
Hi Bobby -
Motorcycling is a matter of freedom and choices. Within those limits, one balances risk versus rewards.
Some find HD to focus and reflect their lifestyle and sense of individuality. Others seek BMW. While others ride the bus, or train.
When it comes to liquid refreshments, water, juice, milk, tea, coffee, soda, beer, wine, spirits, and amped energy drinks provide pleasure and enjoyment.
Here for a good time, not for a long time, my health and wealth affords me the opportunity and ability to enjoy the best that life has to offer.
Simply said, life's way too short to be taken seriously (ditto, your comments.)
Cheers...:bottle
J.K. :wow
P.S. "Nine mile skid, on a ten mile ride, hot as a pistol, but cool inside..."
For 23 years, I have never used a Camelback or anything else. I just stop and get something from my cooler. I usually stop every 1 to 1.5 hours. I'll keep doing what works for me, I suggest others do the same and have fun.:wave
'Camelbacks'? The adult equivalent of a sippy cup. Coolers? Never stay cool. CUPHOLDERS!?
Why do you think God invented convenience stores? :doh
