wattster1
I have a similar problem to yours with my 2016 R1200RS, but it only happens occasionally. I noticed that once in a while when I went to start the bike, it would either struggle, or would not start due to low battery voltage. I checked the battery drain and found that it had a constant 50-80mA drain when that happened. Because of this I now check the battery voltage a few hours or the day after I use the bike. If the voltage is low, I can usually fix the issue by starting the engine and running it for a few minutes then shutting if off. I have done some testing, but have not been able to come up with any reason for the problem or a solution.
Since your problem is constant and seems to go away when you pull the 10A fuse I would suspect the rectifier/regulator might be the problem. Rectifiers have diodes, and when they fail they can cause a short to ground, which will end up discharging the battery after a few hours. Pulling the 10A fuse would isolate the rect/reg from the battery and prevent that problem. You can check this by unplugging the rect/reg and replacing the fuse, then checking the battery current drain.
It was disappointing to hear that the dealer told you that 0.25A discharge current was normal with the engine off. They either don't know what they're talking about or were intentionally lying to you as that is not even close to being normal as my bike has less than 1mA drain when off (measured with a Fluke multimeter). I hope they didn't charge you for that diagnosis. If they did I would report them to the BMW USA Customer Service about the lousy service: CustomerService@bmwmotorcycles.com
