Battery charging an RT
J
Jfixit
The 2003 R1150RT comes with two accessory outlets on the left side of the bike, does it matter which outlet I use when charging the battery with a battery tender fitted with the BMW accessory plug?
Not electrically
It should make no difference electrically. So use the outlet that is most convenient.
They are tied together, however something I have had a problem with on my 02 is the fuse popping. So you may want to make sure it is working. I believe they changed the fuse to be bigger than 4A on 03 and forward, but never hurts to check.
About fuse popping
It is all to easy to ground that metal tip. So I always plug in the jack to the plug and then plug in the Battery Tender.
That's a good idea, but the Battery Tender requires sensing 3 volts when attached to the battery to turn on the smart chip inside. In other words, it won't spark if you ground the plus out of it to the minus when it's plugged into the wall.
Well Designed
That is good to know. I always tried to err on the side of caution. I hope other charging units are as well designed as the Battery Tender.
:wave
