Aux. Lights ?????
kmEatr
any suggestions on light mounts for 97 RT ? i have piaa 910's from other bike, if i can't use those i'll use 2 pairs of something else. many k's to ride at night :D
suggestions welcome, thanks
I'll second what RT Rider said. The EMP brackets are inexpensive, robust, and fit well. Here's a shot with 910's on them.
I had some of these mounts on my RT and found them to be just as Fish said. They were nicely made and Pat Patterson is a very reasonable guy to deal with.:thumb I didn't like my 910's on them though. The lenses protrude out from the housing far enough to throw glare from the lights right into my eyes.:uhoh
I'm 5'11" and had the seat height set in the middle position. I tried one of those wet & stick face shield solar film strips. I mounted it on the bottom of the face shield; it was cut for the top of the shield and didn't fit well, but it did work to keep out the glare. The solar strip was a pain to use, so I traded in my RT and got a GSAdv. Now, no more glare!:D
I've got the EMP over-mirror brackets with PIAA 510s. The driving lights are very effective and I don't get glare from them. I like the brackets, with just a couple small caveats:
1. They do not come pre-drilled, so be careful when you lay out the mounting for your lights that the mounting bolts will clear the painted mirror-housing! Measure twice, drill once....!
2. Mounting the brackets causes the mounting pins for the mirror assembly to change their orientation slightly, just enough for the mirror to be a little bit loose. My fix for this was to apply self-adhesive weatherstripping to the inside of the mirror housing. This keeps the assembly tight. I have also heard that some owners have used o-rings over the pins to accomplish the same thing.
Tim Colburn
Park Forest, IL
