ATV-motorcycle lift compatible with 2006 K1200GT ?
You may need to block the lift as it seems the header collector may be an issue after you remove the belly plastic.
Making assumption it is the two parallel lift pads perpendicular to the lift frame?
I don't recall ever being successful with that style lift, though pretty sure I tried.
Yes 2 parallel lift pads
Removing the plastic would make it easy/easier :)
I was hoping to pick it up move it over and drop it in an out of the way space in the garage
Probly gonna have to make some block to facilitate the pickup, at least the forward pickup point.
Did that with an airhead I had some years ago - worked out nice
Thanks for the comments
HF is within walking distance from me - I was just there yesterday looking for something else
gotta go back and chk out that Pittsburgh roller !
