I just got a couple of the Admore Light Bar and need some guidance, on the instruction they gave me for my 2014 R1200RT they supply the following where to connect the light. I got everything figure out except for the 12 V where they are are saying to use the Rear Accessory Plug, which wire on this plug is the "Switch 12 V"
AdMore Light Bar
(8020-SB) Function 2014 BMW R1200RT
RED Switched 12V Rear Accessory Plug ?? Is it the one that you would use to connect the top case light.
BLUE Brake Light Gray with Black, Yellow dots
GREEN Turn Signal (Right) Blue with Black, White dots
YELLOW Turn Signal (Left) Blue with Red, White dots
BLACK Ground Brown
Also does anyone by any chance would know the wire color for a R1200RS 2016
Switched 12V
Brake Light
Turn Signal (Right)
Turn Signal (Left)
Ground
AdMore Light Bar
BLACK Ground Brown
Switched 12V
Brake Light
Turn Signal (Right)
Turn Signal (Left)
Ground
