bbowers
After plugging in my GPS to my 2005 K1200S yesterday, I accidentally allowed it to draw a charge from the bike for about an hour (bike was not running). When I went to start the bike with the GPS plugged in, the ABS light flashed extremely fast and the brakes stopped working. I shut off the bike, unplug the GPS, and the bike ran as normal (ABS cycled through its function check, the ABS light went out, and I had brakes).
I went on a long ride and attempted to plug in the GPS again. When I started the bike, I again had a fast flashing ABS light and no brakes. I shut off the bike, unplug the GPS, started the bike and I still had a fast flashing ABS light and no brakes.
I shut it down for the night and the next morning it started up and I now have brakes. I have not attempted to plug in the GPS.
So clearly the battery is the culprit to my brake problem. Why? Did I run the battery down too much by accidentally charging the GPS off the battery when the bike was not running? Do I need to replace the battery or can I simply put it on charger for several hours? Should I use a charger or a battery tender?
Any advice is appreciated. Thanks.
