Before I tear into the bike I thought I would ask if anyone has has similar problems with their ABS on a 2000 1150 gs
I have had the ABS lights on the dash blinking top then bottom not both as they should when starting the engine on several occasions
Most of the time if I shut the ignition switch off and restart the two lights flash at the same time and the ABS module resets as I start to drive away from a stop.
However as of late the ABS shows a fault and does not reset even after going through the turn off and restart process, not such a big deal I just do not have ABS braking when this occurs but have the light flashing at me until I push the ABS button again.
Could this be something as simple as a bad connection on the wiring harness?
The bike has only 19,000 miles on it and yes I changed the brake lines from the rubber ones and bled the brakes and ABS module several times
Thanks for you help in advance
Dave
Dave
