I want to order some speed bleeders for my K75S from Speedbleeders dot com. I was going to order five bleeders (two up front, one for the rear and two for each ABS unit).
However, I was told that some owners don't bleed the ABS units. Is there a problem with bleeding the ABS units? Is there a different procedure for getting the old oil out of the units other than opening the valve and squeezing the appropriate handle or pedal? I don't see the point why one would bleed only part of the hydraulic system oil?
Also, any recommendations on the stainless steel version versus the OEM steel versions?
http://speedbleeder.zoovy.com/
Ghyslain
Ghyslain
