Just about every early K100 has had its speedometer replaced under warranty. If not then you get all kinds of funky readings or no readings at all. The IBMWR tech section has a section dealing with these problems.
And since your new to K100's the annoying rattle from the exhaust heat shield is common to. You can futz around trying to keep it quite, or you can take the shield off and throw it as far as you can. This solution is the only permanent fix.
I have a 86 k100 that the speedometer is acting weird. It will usually hang around 20 or 25 MPH and then when I back off throttle it might jump up to the 40 range. I am new to BMW's.
