ezwicky
Member
from Tom Cutter via the airlist, just in case it helps anybody with the same issue on this forum. BTW I am going to follow Paul Glaves' suggestion before I do Tom's fix. So far the first one is not leaking, with 5-weight oil and vigorous plunging of the damper, slider in vise. I'll let it sit overnight, repeat a few times in the morning, then do the other slider.
"That bottom piece is not supposed to be removed. Since you have blundered in there, There IS a chamfer inside that takes the o-ring that BMW does not offer.
I have the replacement circlips and a fat bag of the o-rings in stock. You will also need a tube of Loctite 579 to re-seal and secure that plug when you re-install it. That stuff is $$.
To remove the plug, use the fork tube as a tool from the inside. Heat around the outside of the slider outside the plug, (slip removed, obviously) and tap the fork tube against the inside gently, which will dislodge the plug. "
