m_stock10506
Well-known member
My 1984 R100 stopped charging last weekend. I made it home with 10.25 volts on the battery (only a year or so old). Battery recharged okay and holds the charge. The GEN light is not on when I turn the ignition On.
I pulled the voltage regulator and grounded the blue wire and the GEN light lit up, so I know the bulb and the instrument cluster wiring is okay.
Next, I took off the front cover (disconnect the battery first) and examined the alternator. Took off the stator, tested the rotor - there is no continuity between the slip rings. This indicates an "open" in the rotor. So I ordered a new rotor from EME. The new rotor tests at 2.9 Ohms between the slip rings. I mounted the new rotor and reinstalled the stator. The GEN light still won't light up - not charging.
Is the only other possible issue the brushes? Or, is there something else to check?
