airraceaddict
So, I had been noticing a slow decrease in the mileage on my bike over the last couple of years. I talked to Fred at Big Twin in Boise and also noted that it seemed to be running rich enough to be able to smell it after warm up. No other indications were to be had. Fred's a freakin genius. He said "oh, that sounds like a new needle and needle jet are needed." So, after I got home, I ordered the parts. For around 35 or 40 dollars, I think. Anyways, I "threw" the new parts in, tweaked the carb settings per Snowbum's instructions, went for a 250 ride and BAM! Just like that, went from 38-39 to 53.4 mpg! Checked the plugs to make sure it wasn't running too lean. No problem. Perfect. So, chances are, (and I did see something on another thread about gas smell at speed), there are others out there who could make this same repair and achieve pretty good results. Especially if, (and I have never messed with anything except the floats in 100k) you have high miles and never changed these. Fred was kind of surprised that I got that much of a result, "boy, you are back to factory spec!" but he also said it wasn't uncommon to get another 12 average. I went 250 miles exactly before I switched to reserve which is about the distance I was used to. So there you go. A happy experience at little cost and a BIG difference in fuel savings. Just make sure you get the same jets called out for per the numbers on the jets you remove or factory spec if someone changed them for some reason, (stamped on the side) and that you put the needle at the right setting. Cheers, and hope you get the same result I did, (a fairly drastic increase in mileage on a high mileage bike).
