2023 r1250rs
c10950
Member
Hi there MOA . Some random photos of the 2023 RS that was ordered 4/2023 and delivered 7/8/2023 . Gone to work makin minor improvements like better exhaust, but not louder. 9 pounds total , and very pleasant for touring. Russel Day long build date 9/1/23 . Removed the navigation and used its plug to run the TPX radar .
Heavy into LD riding solo IBA #71825
This is my 1st BMW so for fun I ran the valves at 387 miles to get a base line , sent oil off to Black stone to begin a history for the next few oil changes .
Gave the stock battery to my brother , and installed a Shori unit so the RS is 2 pounds lighter than stock with its rear side bags .
1st valve check at 387 miles.jpgRS with Full exhaust.jpgRS full Tour.jpgAkro exhaust from side.jpg
Willkommen C10950 from the Tenn River valley!
U seem to be an engineer by nature; already “improving” BMW’s mediocre design efforts. :dunno
Surely hope that this new import into your garage will add exuberance to your critical need for speed.
Have Fun with your new BMW in 2023; maybe you’ll resurface at an MOA Getaway or the International Rally in Redmond, OR in June 2024. :thumb
Happy Trails whenever U can - Ciao!
HSV-Phil & HSV-Karen
USAF-Ret'd — & — USN-Ret’d
'75 R90S ————— '82 R100CS
’09 KLX250S ——— ’08 CRF230L
'14 K-GT ————— '16 R1200RS
’05 Vespa 200L
:beer
I also just got an RS on 30 June and want to take off the stock GPS cradle. Which panels did you need to remove to get to the plug?
I'm a little more hesitant to dive in and start tearing things apart on a brand new bike than you seem to be, so any advice would be appreciated.
the GPS plug in on throttle side just behind radiator cap . I have a service manual that show body work removal . You only need to pull right upper on fuel tank .
It has a male clip that inserts @ 6 into the right front body panel . You simple lift it out . there are 3 clips on the fuel tank center joint to make sure you align before
inserting them on reinstallation.
While the RS is quick its not fast by my definition. I grand toured on a custom one off Hayabusa I built over 5 years with 207 RWHP and 113 tq @ 498 wet weight
full of fuel . I miss it greatly . The wife , and friend talked me into adventure bike , and I was the only one who rode after the purchase on a Tiger1200XCX .
Great bike but heavy , and slow . Got spoiled to shaft drive and single sided swing arm . I did not want to build another Hayabusa grand tour rig so closest
bike to it is the RS with shaft drive , center stand , and swing arm I like .
I took mine off within a couple of days of purchase of the bike. I traced the cable down and looked where it connected to the loom. I then carefully removed the right side panels, clipped the zip ties, and unplugged the cable. While doing this I discovered that one of the winglet fasteners was missing. I also discovered that there are two different lengths of fasteners for the panels.
Here's a picture.
